DIAdem
Length of data on XY plot
How can I change the length of data that is taken into the XY graph?
I do not want to have a graph of the entire waveform, and only select a fragment of it. How to change the number of samples that are taken to the chart?
(3,203 Views)
Hi spalinowy,
Both in DIAdem VIEW graphs and DIAdem REPORT graphs you can specify the desired X axis range that you want to display, by choosing the Xstart and Xstop values for the X axis.  In VIEW you do that with the sheet's cursor and zooming.  In REPORT you do that in the Graph's Xaxis configuration dialog.
Brad Turpin
DIAdem Product Support Engineer
(3,151 Views)
Not exactly what I meant. I want to draw a graph with a lissajous figure and I want to have data in the drawing only from a certain time interval. However, amplitude is to be in full range.
(3,144 Views)
sometimes I do something similar. For example, show only the "main process time", without heating-up and cool-down phase.
The most easy way I found is to create a new channel (just copy) and set the values of no interest (e.g. from T=0 to T=123) to NoValue.
This can be done via script and for different channels with different settings, only the times must be set/changed once. And (at least in my case) it's not needed to save the changed data file; create new channel, update the Report and export it, than close all.
(3,129 Views)
