DIAdem
Linear Regression - set intercept = 0?
Using a linear regression, is there a way to set the intercept to zero?
(4,894 Views)
I'm not sure if I understood your question correctly, as far as I know Diadem sets the intercept for you.
For the regression function, DIAdem calculates the regression coefficient a, the regression coefficient b (where b is the intercept), and the determination coefficient r2.
Could you please tell me what your application is aimed at in this case.
Thank you
Nandini Subramaniam
NI
(4,885 Views)
This annoyed me for a short while when I first started using Diadem.
Instead of trying to run a linear regression, you can use non linear curve fitting and change your setup function formula from a+b*x to simply b*x (or similar). This ensures that your fit intercept is 0.
CLA
(4,420 Views)
