DIAdem
List box - how do I save the names of items selected by mouse?
I have a created a dialog with a list box.  Using script, I want to load it with all the channel names from a group and then manually select some of these channels with the mouse (multiselection mode) and store them in an array.
Using script, I can load the channels, select some or all them and store them in an array.  However, I do not know how to store manually selected channels in an array.   In other words, how to get highlighted channels into an array?
Any help is gratefully appreciated.  Thanks.
(5,729 Views)
You just need to acces to the multiselection() method of the ListBox.
So you just need.
Dim i For i =1 to ListBoxObj.Multiselection.Count Msgbox ListBoxObj.MultiSelection.Item(i).Text Next
 and Actually ListBoxObj.Multiselection is already a collection, so you can used or reasigned to a new array variable.
(5,711 Views)
Thank you Naoa!
(5,698 Views)
