DIAdem
Listbox get items to script
how can i transfer the items (names) of a listbox to script.
(6,182 Views)
Hi AndiMEC,
Do you mean a listbox control in a SUDialog?
Brad Turpin
DIAdem Product Support Engineer
(6,170 Views)
Hi Brad
i have a dialog with a listbox and a (channel)combobox from which i add any number of channels to the listbox. Now i need to get all the items(Channels) which are in the listbox to my script for further analysis.
(6,163 Views)
just add all Elements to an Array or Dictionary and give this Oject to your Script:
In your SUD:
Dim aTmp()
  Redim aTmp(listBox.Items.Count - 1)
  For i = LBound(aTmp) To UBound(aTmp)
    aTmp(i) = listBox.Items(i+1).Text
  Call Dialog.SetArgument(aTmp)
Now in your VBS:
Dim i, aChannels
If (SUDDlgShow("name", sPathToSUD, aChannels) = "IDOk") Then
  For i = LBound(aChannels) To UBound(aChannels))
    Call LogFileWrite(aChannels(i))
End If
(6,147 Views)
Hi AndiMEC,
Execute this code in the SUDialog and pass the ChanNames variable back to the calling VBScript.  You may probably have to change the name of the control from "ChnCombobox1" to whatever you called it.
  Dim i, iMax
  iMax = ChnComboBox1.Items.Count
  ReDim ChanNames(iMax)
  FOR i = 1 TO iMax
    ChanNames(i) = ChnCombobox1.Items(i).Text
  NEXT ' i
  MsgBox Join(ChanNames, vbCRLF)
Brad Turpin
(6,125 Views)
