DIAdem
Load File into Diadem 9.1 and create a 3-D graph
I have a problem to load the attached file into DIAdem 9.1 and create a 3-D Graph !
(3,227 Views)
Hi Messer,
I've looked over your CSV file and honestly don't know how to interpret the data.  It looks like your bulk data is in lines 31 - 41, but are the data channels arranged as rows or columns?  Where are the channel names located, and what should be done with the X_AXIS_PTS and Y_AXIS_PTS values?  Are the ETK ADRESS_MAPPING values file properties or channel properties, and do you want them imported at all?
Brad Turpin
DIAdem Product Support Engineer
(3,221 Views)
