DIAdem
Manage Report Table Column width using DIADEM scripts.
I have a table with n columns in a Diadem report page. The column 1 contains header information, so I want it to be always at constant width. Remaining columns should equally occupy the rest of the available width, it may be 2 or 3 or 4 columns based on test condition.
is there a way to have different width for different columns in a report table?
is there a option to use autofit the column width based on the text content inside the column?
Durai
(1,491 Views)
Hi Durai26,
DIAdem Report tables have the option for different sizes per column.
You can change that in the settings dialog or per script as below:
Dim oCtrl, dWidth, dWidthRest, dWidthColA, dWidthPerChn, iNoOfChn, iLoop
Set oCtrl = Report.Sheets("Sheet 1").Objects("2DTable1")
dWidthColA   = 20
iNoOfChn     = oCtrl.Columns.Count
dWidth       = 100 - oCtrl.Position.ByBorder.Right - oCtrl.Position.ByBorder.Left
dWidthRest   = dWidth - dWidthColA
dWidthPerChn = dWidthRest / iNoOfChn
oCtrl.Columns(1).Settings.RelativeColumnWidth = dWidthColA
for iLoop = 2 to oCtrl.Columns.Count
  oCtrl.Columns(iLoop).Settings.RelativeColumnWidth = dWidthPerChn
next
Greetings
Walter
(1,461 Views)
