DIAdem
Maximum data size in DIAdem
Is the 2 billion points x 65000 channels limit still the case?  Even with 64-bit DIAdem?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
Message 11 of 12
(937 Views)
Hello Terry,
Yes, the 2 billion by 65,535 channels limit is still in place, even in the 64-bit version of DIAdem. The advantage of the 64-bit version is that it can make use of all available RAM, so there won't be swapping above the old 2GB limit for 32-bit applications if you have sufficient RAM.
It is possible to load subsets of files, so we can handle files with more than 2 billion values, but DIAdem will only load 2 billion values per row in a total of 65,535 channels.
Do your files have more rows or channels than the current DIAdem limit?
     Otmar
Otmar D. Foehner
Message 12 of 12
(930 Views)
