DIAdem
Memory consumption using cvitdms.dll
Hi all!
I am using a Diadem library to create .tdms files
Through the DLL, I create and open a file and so, I start to append data values.
When I look at the task manager, I can note that the memory consumption of my application does not stop to increase until I stop my program.
I also tried to start the program without start the logging methods, that use the tdms libraries, and so, this behavior does not occur.
I flush the data every 30 seconds or every 500 registers.
How can I solve this problem of memory consumption?
Regards
Gustavo
(3,560 Views)
Hey Gustavo,
Do you have a small program that demonstrates this behavior?  If so, could you please upload the CVI source so I can reproduce your issue here?  Also, what version of CVI are you using?  I look forward to hearing back from you!
Best Regards,
Software Engineer
Jett R
(3,530 Views)
I am using CVI 8.1.1
The cvitdms.dll version is 8.1.1.361
When I just load or open a file it consumes 250MB of memory.
I will post some code to you evaluate.
Regards.
(3,516 Views)
