DIAdem
Merge alarms and other Info to scheduled automatic email (including alarm and status Logfile)
I am evaluating DIAdem these days.
My task is to keep track of a running test, checking the data for prespecified tolerances and safe a logfile consisting of the test progress and alarms.
I build a small Program using DAC, there is also no problem in sending alarmtexts via email.
Here my question:
How can I merge alarms and other textinformation to one single email  - let's call it status report - which will be sent scheduled once a day?
Using DAC is prefered.
Thank's a lot!
Michael
(2,499 Views)
Hi Micheal,
yes you can merge alarms and other other text with the alarm multiplexer block.
There is an example at:
Help> Examples> Measuring, Testing, Automating, and Visualizing> Alarm System> Critical Alarms Linked to a Master Alarm
(2,456 Views)
