DIAdem
Multi order equations apply to channel
Hi Group,
I have  a issue that would be create a rather long calculate command, and I was hoping there was a better way!
I have multiple channels that I am reading into Portal with a Dataplugin.  So what ever handles the multi order equation, must work inside of a dataplugin.
The equations are 14 orders long, and will be applied to all values in a channel.
The order values are in a double array.
What would be the script that would do this inside of a Dataplugin?
Thanks for your help in advance.
Paul
Paul
Message 1 of 1
(2,420 Views)
