DIAdem
Multiple pictures export from Report via script
Hi
I have datas divided on groups. These groups contains several channels. Example names from Data Portal:
[1]/Angle
[1]/Torque
[2]/Angle
[2]/Torque
[3]/Angle
[3]/Torque
and so on.
I found example scripts which I adopted for my needs.
I needed to average all those channels and a part of this script responsible for this action works fine.
Here piece of code:
' Subroutine for data analysis
sub sDoAnalysis
dim i
iMyIntVal = 10  ' Variable for dialog control
if SudDlgShow("Input_1","c:\SudExample") = "IDCancel" then
    iMyIntVal = 0
end if
For i=1 to iMyIntVal
STATSEL(1)       ="No"
STATSEL(2)       ="No"
STATSEL(3)       ="No"
STATSEL(4)       ="No"
STATSEL(5)       ="No"
STATSEL(6)       ="Yes"
STATSEL(7)       ="No"
STATSEL(8)       ="No"
STATSEL(9)       ="No"
STATSEL(10)      ="No"
STATSEL(11)      ="No"
STATSEL(12)      ="No"
STATSEL(13)      ="No"
STATSEL(14)      ="No"
STATSEL(15)      ="No"
STATSEL(16)      ="No"
STATSEL(17)      ="No"
STATSEL(18)      ="No"
STATSEL(19)      ="No"
STATSEL(20)      ="No"
STATSEL(21)      ="No"
STATSEL(22)      ="No"
STATCLIPCOPY     =0
STATCLIPVALUE    =0
STATFORMAT       =""
STATRESCHN       =1
Call STATBLOCKCALC("Channel","1-","'["& i &"]/Angle' - '["& i &"]/Torque") '... STATDIREC,ROWNOSTR,CHNNOSTR
if i=1 then
Call Formulacalc("Ch('[1]/Angle') := Ch('[1]/Angle') - ChD(1,'Arithm_mean')")
Call Formulacalc("Ch('[1]/Torque') := Ch('[1]/Torque') - ChD(2,'Arithm_mean')")
else
Call Formulacalc("Ch('["& i &"]/Angle') := Ch('["& i &"]/Angle') - ChD(1,'Arithm_mean"& i-1 &"')")
Call Formulacalc("Ch('["& i &"]/Torque') := Ch('["& i &"]/Torque') - ChD(2,'Arithm_mean"& i-1 &"')")
end if
next
end sub
iMyIntVal is defined as a Global variable
In user dialog box I can enter number of samples to process.
I have a diagram ready in the Diadem Report so I have to replace data channels and export the graphs to .png files one by one.
Example:
axis X -> [1]/Angle
axis Y -> [1]/Torque
axis X -> [2]/Angle
axis Y -> [2]/Torque
axis X -> [3]/Angle
axis Y -> [3]/Torque
--> export to sample_3.png  and so on.
How can I do this automatic via script based on number of samples that I enter in user dialog box ?
Thanks in advance.
(3,364 Views)
Hey Domin,
To start out with, I would recommend trying to use the script recording capability to record your actions and then try to emulate that code in your larger application.
Andy McRorie
NI R&D
(3,327 Views)
