DIAdem
NI 9205 input ranges of ±200 mV, ±1 V, ±5 V, and ±10 V in MAX
how can I use the  programmable input ranges of ±200 mV, ±1 V, ±5 V, and ±10 V from NI9205 in MAX or in Diadem DAC?
Thanks!
(1,739 Views)
While C Series modules are used with cDAQ and cRIO chassis and controllers, their ... The NI 9209 is a 24-bit module with ±10 V range , which means that lowest ... The NI 9220 has an input impedance of TellPopeyes Survey >1 GΩ. Taking ... on NI 9205, which has a maximum working voltage of ±10.4 V
(1,688 Views)
Thanks, but I don't understand your answer. Could it be possible, that this is not all of the text? Or should there be a link?
(1,680 Views)
Hello Kada69,
To use NI hardware in DIAdem DAC you must define a Global Virtual Channel in MAX. There you can configure the module specific settings like different input ranges. The name which you defined for such a channel can be chosen in the NI-DAQmx-Driver block.
Greetings
Walter
(1,646 Views)
Hi Walter,
thanks, it works.
But this is not the way I hoped for. In this way will be used the input range "automatically", not fixed.
Kind regards
Kada69
(1,626 Views)
