DIAdem
NIC calculation through Crash analysis toolkit in Analysis tab (Diadem 12)
Hi, In the description of ChnNICBdryCalc function in the help file it is mentioned that 'Calculates the Neck Injury Criterion value (NIC) according to ECE.' while the at the bottom of the same page it is mentioned that 'The NIC calculation in DIAdem 11.0 and earlier versions is different. DIAdem now uses the cumulative calculation of all peaks according to the EuroNCAP. You can use Time at Level for a continuous calculation within a peak.' as a note. ( pls refer attached picture). Both these statements are contradicting each other. Can someone help me and confirm what method (continuous or cumulative) is used by the function for calculation. What about other 'Time at level' functions like Femur force criteria (FFC calculation) is there any such difference in it? Thanks in advance. Regards, Fazil
(3,590 Views)
Hello Fazil,
Can you attach a snapshot of the same.
Cheers,
Rao
(3,511 Views)
Sorry, forgot to attach picture earlier. Pls refer attached.
Fazil.
(3,505 Views)
