DIAdem
OOP class inheritance
I'm using DIAdem for making large PDF reports based on measurement data. I'm using classes, but it would be a big advantage to have class inheritance functionalities. As far as I know VBS doesn't provide inheritance functionalities (i'm not so familiar with VBS). Is there any possibility to use class inheritance in DIAdem for generating reports?
Raphael
(5,610 Views)
There is no inheritance in VBS.
But because VBS is name oriented something like a virtual interface works out.
Option Explicit
class A
  Sub SayMyName()
    Msgbox "I am A"
  End Sub
end class
class B
  Sub SayMyName()
    Msgbox "I am B"
  End Sub
end class
Sub LetItTalk(ByRef obj)
  obj.SayMyName
End Sub
dim aObj : set aObj = new A
dim bObj : set bObj = new B
LetItTalk(aObj)
LetItTalk(bObj)
 So LetItTalk works with any class that implements the SayMyName method.
(5,607 Views)
Hi Andreas
Thanks for the answer, it works like that.
Regards
Raphael
(5,561 Views)
