DIAdem
Object required : 'navigator.display.currdataProvider'
I have installed Diadem 2017 on my Professional computer this morning and after the end of the installation and the reboot of the computer, I got the error "Object required : 'navigator.display.currdataProvider'" appearing after the launch of Diadem.
I tried to reinstall but the same error appears.
Could someone help me to fix this ?
Thanks, regards
Message 1 of 8
(4,434 Views)
Hello FIVES,
It seems that during the installation process something was not correct registered. To solve this please try the following:
  • Close DIAdem
  • Double-click the file "uspSUsiMyDataFinderClient.uri" in the folder "c:\Program Files (x86)\National Instruments\Shared\DataFinderDesktop\bin\".
If this doesn't help try to repair DIAdem.
Greetings
Walter
Message 2 of 8
(4,407 Views)
Hi Walter,
Thanks for your reply.
I try the first option you gave me. Result is the following picture.
For the repairing of Diadem, I don't know where I can find the execute file. Could you tell me more about ?
Message 3 of 8
(4,405 Views)
Hi FIVES,
For the repairing option, you must open the OS area programs and features. There you find National Instruments Software. Double -click it, select the DIAdem version and Repair.
Greetings
Walter
Message 4 of 8
(4,397 Views)
Walter,
I've tried to repair Diadem, but as you'll find attached, I don't have any option for this. I can only remove the software.
Thanks for your help,
Message 5 of 8
(4,392 Views)
Hi FIVES,
It seems that you have installed one of the latest NI software products which provide a new kind of installer tool (Package Manager). In this case you have only the option to uninstall and install DIAdem again.
Greetings
Walter
Message 6 of 8
(4,382 Views)
I am having the same issue plus additional issues with DataFinder in DIADem (attached) and have attempted to repair and reinstall both DIAdem and LabVIEW with no luck for solving this problem.
Has the previous user (FIVES) found a solution?
Message 7 of 8
(4,244 Views)
SOLVED
According to previous reply, I found "uspSUsiMyDataFinderClient.uri" and running this file solved my problem.
Thanks!
Message 8 of 8
(4,237 Views)
