DIAdem
Only Pinned Objects
Is there any function to show only pinned groups in data Portal to read it with expression
I want to select only pinned groups with Fail
is there something like this
@@Data.root.channelGroups.pinned(D2TabRow).Properties("Name").Value@@
(1,644 Views)
Accepted by topic author damdoum
Hi damdoum
Here you can find the expression for pinning the groups.
Regards)
_______
Best wat to thanks is to give Kudos / Mark as a solution.
(1,610 Views)
I want to use it in a table expression
can you schow me the expression 🙂
(1,599 Views)
