DIAdem
Open Comtrade file with DIAdem
Hello to all,
I need advice with opening Comtrade file using DIAdem.
This comtrade file is created with LabVIEW 2011 with Comtrade library. I need open this file with DIAdem 2011 with comtrade plugin (picture below). For this Comtrade file i have set up timestamp multiplier on 100 value. It should recalculate all of timestamps as timestamp x multiplier.
 but it doesn't!
I tried open this file with other comtrade viewers and time is displayed correctly in all of them.
Have anyone some solution, why this timestamps are not recalculated with multiplier with DIAdem???
Thanks to all!
Lada Smiley Happy
Message 1 of 11
(7,535 Views)
Hi Lada,
Is the COMTRADE file generated by LabVIEW Electrical Power Suite?
Would you please attach the file so that we can dig deeper into it?
Thanks!
Liqian
Message 2 of 11
(7,516 Views)
Hi Liqian,
Yes, this Comtrade file is created by LV EPS. File in attachment.
I have some issues with upload 24MB *.dat file, so here is link to download:
https://drive.google.com/folderview?id=0Bz_YUJSQRbw8fkZKbHR4NDRuREZQVTlhb1B6LXRmNnhjMVNWeTh1ZUVMSFpK...
Lada
Message 3 of 11
(7,510 Views)
Hi Lada,
Unfortunately, I can't download the file successfully. It indicates that "Google Drive is currently unreachable".
Can you try some other way to attach the file? Do not use Google Smiley Tongue
Thanks!
Liqian
Message 4 of 11
(7,488 Views)
Hi Liqian,
I sent this files to my Dropbox. Hope You be able to download this files from there 🙂
https://www.dropbox.com/s/0xqwkg20hszrjn4/20141208.zip?dl=0
Lada
Message 5 of 11
(7,459 Views)
Hi Lada,
LabVIEW Electrical Power Suite also supports reading COMTRADE files. I opened the files you attached with EPS COMTRADE example. It seems that the time multiplier works. You can have a try.
Thanks!
Liqian
Message 6 of 11
(7,418 Views)
Hi, Liquian
I know, that this multiplier works, because I open this COMTRADE file by PQDiffractor and wavewin32 Comtrade viewers and everything is OK. But I would like to know, why DIAdem don't open it correctly.
Lada
Message 7 of 11
(7,394 Views)
Hello Ima22,
It seems that this parameter (multiplier) is not supported correct from the DataPlugin. We will fix that and update the DataPlugin download web page soon.
Greetings
Walter
Message 8 of 11
(7,369 Views)
Hello Walter,
Thank You! Is there some possibility to send me feedback, when this data plugin will be updated? 🙂
Lada
Message 9 of 11
(7,358 Views)
Hi Lada,
we expect a first version to be ready for testing in the first week of April.
Stefan
Message 10 of 11
(7,311 Views)
