DIAdem
Opening a Somat .sie file in DIAdem takes forever
Hi All,
I'm new to DIAdem but know LabVIEW well. I am trying to open a Somat .sie file. I have the Somat .sie data plugin installed and DIAdem sees the file fine but it takes forever to load. The file opens fine using SoMat InField (and very quickly). I've attached a sample for you to take a look at.
Anyone who can pop it open straight away?
Phil
(6,807 Views)
Oops. Never attached the file.
Change .txt to .sie.
(6,806 Views)
Hi Phil,
Can you please also provide an ASCII file that contains the same channel values as your sie file? It can help a lot for us to fix any bugs in the DataPlugin. Thank you.
(6,797 Views)
I exported the data as "Verbose ASCII with time" using SoMat InField. The 4MB file became 110MB! I've uploaded the file to WeTransfer. The link to download is here. I hope it works ok. Let me know if you need anything else.
http://we.tl/cvym2kWpEX
Phil
(6,786 Views)
Thank you Phil for the ASCII file!
We are investigating the problem and will let you know if any updates.
(6,763 Views)
Please find a new version of the DataPlugin from
http://zone.ni.com/devzone/cda/epd/p/id/6616
And let us know if there is any problems.
(6,708 Views)
