DIAdem
Oscilloscope always in the foreground
Hello users and experts here,
I am a new user of Diadem and now find the setting of Oscilloscope is annoying, as shown in the attachment. I would like the Oscilloscope window to be in the foreground of Diadem, but not in front of the windows of explore or other software.
There is a selection 'Foreground Window', if I unselect it, and then start the measurement, then the Oscilloscope will even not be shown in the foreground of Diadem. It will be hidden. so this seems not to be a solution.
How could Oscilloscope be embeded on the 'Visual' page, just like the display instruments for single point proceesing?
(5,476 Views)
Hi Ruyee,
thank you for using the National Instruments Forum.
What you experience is expected behavior. The Oscilloscopes that are used for data visualization in the example are not part of the VISUAL page but they are windows of their own. You can see them in the Windows taks bar. Their borders, title bars and menu bars have simply been hidden.
To visualize data within the VISUAL page, simply use indicators that are not windows. Paket data does not offer such embedded indicators but you can single out your data before visualizing (German: "Vereinzeln"). See screenshot.
Also, have a look at the great visualization examples that ship with DIAdem.
Regards, Topper
(5,444 Views)
Hi Topper,
thank you very much for your reply. I understand your solution. In this case it helps. however actually I have used a bad example. Actually we use Oscilloscope to display the FFT result (Amplitude as Y-Axis and Frequency as X-Axis). So in this case it seems not possible to single out the data, and a solution is still pending
(5,440 Views)
