DIAdem
PDFExport Dialog
  I use Diadem 10.1 and i want to export a report to a PDF file. I do it with PicPdfExport but I want to display the dialog box to choose the filename and the forder to save it.  Is it possible to call in a script a function like PicPdfExportDlg?
Oriol.
(3,563 Views)
Hi Oriol,
You can use the following syntax:
' opens dialog for path and file name setting
if FileNameGet("ANY", "FileWrite", "D:\Test\", "PDF file (*.PDF),*.PDF") = "IDOk" then
  ' msgbox FileDlgFileName
  PrintName = "winspool,DIAdem PDF Export,LPT1:"
  PDFFilename=FileDlgFileName
  PrintRangeType = "PageEnums"
  PrintFromPage = 2
  PrintToPage = 4
  Call PicPrintDlg("WinPrint") ' opens dialog for PDF parameter setting
  'Call PicPrint("WinPrint")
end if
Greetings
Walter
(3,552 Views)
