DIAdem
PGN and SPN display in Dataportal / channels
I'm trying to see if there is a way to include PGN's and SPN's in the channel's in the data portal, in such a way that it can be searched using the channel and group filters.
I am using the bus log converter to convert a J1939 log, using a vector DBC for the channel assignments. The bus log converter converts the SPN's and PGN's into their noun names in the DBC, but I would like to have the numbers available for search in the data portal in Decimal.
Is there any way to do this without having to go in and manually add the information to the signal assignments in the DBC.
Message 1 of 1
(1,137 Views)
