10-03-2008 02:35 AM
Please give me an example on how I can Set the PDFAppend variable for the following command
Call PicPdfExport(PDFFilename, [PDFAppend])
The Aim is to save several pages of a report generated by a for loop in a single Pdf File:
each iteration I need to append a new page to append to the existing File
Best Regards
Marco
Solved! Go to Solution.
10-03-2008 03:51 AM
Hello Marco
Call PicPdfExport("C:\DD.pdf",true)
should work (tested in DIDem 10.2).
Matthias
| Matthias Alleweldt Project Engineer / Projektingenieur | Twigeater? |
