DIAdem
Peak Integration in Diadem
Hallo I received an evaluation version of Diadem with LabView. Is there any way to let's say integrate certain peaks from a chromatogram ? I saw it can find the maximums in the spectrum but did not see any standard routine to integrate that particular area. Thank you
(3,444 Views)
to analyse a particular area you must copy this values into new channels (columns). Therefore you can esyly use the panal DIAdem VIEW. You can drag&drop the original channels into a 2D-axis system, define a band cursor (icon on the top), mark the area (icon in the current window) and copy (icon in the current window)it. Now you can use the mathematical function you would like.
Kind regards
Walter Rick
(3,444 Views)
