DIAdem
Perform Distinct on channel
Let say i have this channel values : 1111111111111111222222222222333333331213212321144445
i want to preform a distinct operation and get this channel: 12345
how i do that?
can i get the same effect on Text channel? (on,on,on,on,off,off,off,on,on,on  >>>> new channel: on,off)?
(4,881 Views)
Hi OzShimon,
You need a script in which the VBS dictionary is used to do that. Attached you find this as example. The script function "CreateUniqueItemsAndIndex" of this example has three parameters:
a) the source channel (which can have the types numeric or text)
b) the index channel in which the position of a unique content is stored. The index channel refers to c)
c) the unique content which is extracted out of a)
Greetings
Walter
(4,877 Views)
