DIAdem
Performance Test
Hello!
I want to do some simple, reproducible performance test to compare DIAdem, with other measurement data analyzer software.
In this test the software do some channel operations (eg. Calculate average). After the first run of the script, this calculation was much slower, than the next one. Probably some data stayed in the memory, but i really want to know why.
I use this script:
Call Data.Root.Clear()
Call LogfileDel()
Dim Start
Start=Timer
Call DataFileLoad(".")
Dim Load
Load=Timer-Start
Call MsgboxDisp(Load)
Dim start2
Start2=Timer
Call ChnAverage("'[1]/[1]'-'[1]/[20]'","[1]/Average")
Dim Finish
Finish=Timer - start2
Call MsgboxDisp(Finish)
Thanks for the answer.
Gergo
(2,915 Views)
Accepted by topic author Gergo.F
Hi Gergo,
I assume this is because of the settings in the loading behavior.
Greetings
Walter
(2,855 Views)
