DIAdem
PicExport saving same file everytime in DIAdem 2012
I noticed this problem with the built-in PowerPoint Export menu selection in DIAdem 2012. It used to work fine in DIAdem 2011.
I've traced it to the PicExport function. The sample code below should demonstrate the problem. If I have 1 or 2 Sheets in REPORT, it only exports the image for the first sheet. If I have 3 or more, it only exports the third sheet. The number of exported files is correct, but the image files are always of the same sheet in DIAdem 2012.
Thanks!
Greg Granville
(5,670 Views)
Accepted by topic author Greg_Gran
I tried your script, and it works correctly on my machine (I also have DIAdem 2012).
But, try to add command:
"call report.sheets.item(i).activate"
on the line 28 in your code.
Simyfren
(5,649 Views)
That fixed it - thanks!
I believe that means that the script which is called when you select "PowerPoint export..." from the File menu may need to modified in DIAdem 2012 if others run into this problem. It worked fine as is in DIAdem 2011 for me.
(5,636 Views)
