DIAdem
PicPdfExport is very slow
Hi All,
I had a script in V 11.1 where I used to get all my reports in pdf, wmf and png format.I am using PicPrint for that in my script.
The same script I am using in version 12 and the pdf printer gets hanged and i never get pdf plots. So i am using picPdfExport instead of PicPrint and it works fine. But it takes nearly 40 seconds to print 1 plot and its so much time consuming.
Is there a way to resolve this ? What is that changed in Version 12 about pdf export?
Rashmi
(5,214 Views)
Hi Rashmi,
I don't know of anything that changed in DIAdem 2012 and am perplexed at your symptoms.  Would you please post the script you used to export to PDF using the PicPrint command?
Brad Turpin
DIAdem Product Support Engineer
(5,200 Views)
