DIAdem
Picture Orientation
Hello All
I have developed some report templates that assume that all images will be in Landscape mode however it appears that sometimes my techs forget this and take photos in portrait mode.
I have stumbled across the "LoadPicture" function and I have found a way to create an image object however I cannot seem to find additional documentation (on the web) on of the methods or properties associated with the object.
Basically I would like to check if an image file on disk is either in portrait or landscape mode and rotate the image if need be.
Any help would be appreciated
Tim
(2,871 Views)
Accepted by topic author smoothdurban
I found a viable work around  see below
Set miDoc = LoadPicture(file)  'Where file is full image file path and name
If miDoc.height > miDoc.width Then  'Logic being if the height > width the photo is in portrait mode
Call WIA_RotateImage(file, file, 270)
End If
Function WIA_RotateImage(sInitialImage, sOutputImage, lRotAng)
    Dim oWIA                     'WIA.ImageFile
    Dim oIP                     'ImageProcess
    'Should check if the output file already exists and if so,
    'prompt the user to overwrite it or not
    Set oWIA = CreateObject("WIA.ImageFile")
    Set oIP = CreateObject("WIA.ImageProcess")
    oIP.Filters.Add oIP.FilterInfos("RotateFlip").FilterID
    oIP.Filters(1).Properties("RotationAngle") = lRotAng
    oWIA.LoadFile sInitialImage
    Set oWIA = oIP.Apply(oWIA)
    DeleteAFile(sOutputImage)
    oWIA.SaveFile sOutputImage
End Function
Sub DeleteAFile(filespec)
   Dim fso
   Set fso = CreateObject("Scripting.FileSystemObject")
   fso.DeleteFile(filespec)
End Sub
Not the most elegant solution but it does work.
Tim
(2,833 Views)
