DIAdem
Placing items from ChnMultipleSort into seprate channels
How do I place related items after using ChnMultipleSort in to separate Groups?
Name           Data1     Data2                Data3         Data4        Dat 5
AIOMain        200       216126364      216102364      1936        2872
AnalogIOMgr 200     26150808         216126808     1040        1072
BootMgr        200     216507488       216459488      1040      2540
CPMTask      200     215946968       215922968         500          628
Here are six  columns of data they were sorted by the first column(name)   How do I place each row of five pieces of data into its group.  For example the first group would be called AIOMain with each data having is own channel?
(3,487 Views)
Hey JReynolds,
It sounds like you want to create a new group for every row, and all of this data is already loaded in the Data Portal.  If you want to make a new group in the Data Portal, you can call the GroupCreate("MyGroupName") function.  You can find the resource page for it in the DIAdem help.  If you are trying to make this happen in a DataPlugin we need to go a different route.  If this isn't what you are looking for, could you give us a little more insight into what you are trying to accomplish.  I look forward to hearing back from you.
Best Regards,
Software Engineer
Jett R
(3,465 Views)
