DIAdem
Plotting Graph in VIEW with only points (no lines)
Hey guys, I hope everyone reading this is doing well.
Well the problem I have is that I want to draw graphs in the "VIEW" Panel with just points (no lines).
I can achieve this in the "REPORT" Panel, but I can never do the same in the "VIEW" Panel.
I will attach images of what I mean for clarification.
'I tried to apply this line of code to change the line width to "0" but as expected I got an error message alerting me that 0 is not a value of the enumeration.
oCurves1.MarkerLineWidth            = "0
I am using DIAdem 2015 fyi. Please help!
Thanks in advance,
Tim
(3,405 Views)
Accepted by topic author kmyan9
Hello Tim,
just tried out the following with DIAdem 2017 (should work with 2015 as well):
Select Markers
Make sure to set a specific color (not just "use curve color")
Set Curve color to "nothing"
You should see something like this:
(3,361 Views)
Hi Andreas!
Thanks to you, it works perfectly!
Hope you have a wonderful day!
-Tim
(3,357 Views)
