DIAdem
Preview field length in DIAdem ascii import assistant too small
I am evaluating the DIAdem 8.0 software, and cannot seem to get around the field length of the preview in the ascii import assistant. The default field is 10240 bytes, my file header is much larger than this (I don't make the files, I just use them ;). If I can't see the headers, I cannot properly import the file. Is there a variable available to increase the default size on the preview field? Adjusting the memory options doesn't seem to affect the field size at all...
(6,607 Views)
Could you ZIP your ASCII file and upload it here, I would like to try to find a solution to your problem and need a file for testing.
You might want to provide a file with 'uncritical' i.e. non-confidential data, as everybody will be able to download your file once you make it available here.
I look forward to receiving your file.
Otmar
Otmar D. Foehner
(6,606 Views)
I've had to strip most of the structure from the header, but the same effect still occurs with the stripped file.
Thanks for any help!
(6,606 Views)
I need to get more information from you to help out with this. Please call me at (512) 683-5452 at your convenience.
Otmar
Otmar D. Foehner
(6,607 Views)
