DIAdem
Print Y axis Name in Legend
we have a report that we use to print multiple result on multiple Y-AXIS. The problem is that in the legend, we only see the name of the channel, but not the name of the Y-AXIS that is associated with it.
Is there a way we can print in the legend the channel name and the Y-AXIS number that the channel is associated too ?
(4,114 Views)
Crusader,
there is no variable you could reference to print the y-axis number in the legend. Could you please explain why you would like to see teh y-axis number in the legend?
Perhaps we can recommend an alternative solution once we understand what you are trying to achiev.
Andreas
(4,094 Views)
here's what we are trying to achieve :
Print 6 variables on a graph.
1-2 are on axis Y1
3 are on axis Y2
4-5-6 are on axis Y3
When this graph is export in a pdf (or anything else), the user receiving the graph has no way of knowing what axis is related with wich variables. We would like to see in the legends something like this :
1 - Name of the variable | Axis Y1
2 - Name of the variable | Axis T1
3 - Name of the variable | Axis Y2, etc...
(4,033 Views)
Hello Crusader,
DIAdem 2011 (available this summer) adds a new function that allows to create more elaborate axis labels.
I have attached two images for you that show the new CurveSnippet function of DIAdem 2011:
If you think this function might be useful to you, please check out the DIAdem BETA version 2011 here (requires sign up):
http://www.ni.com/beta
Let us know if that helps,
      Otmar
Otmar D. Foehner
(4,030 Views)
Hello Crusader,
If you use a free text for the legend display, you can build the string you want like this:
Axis @@CurrAxisNo@@ | @@ChnName(CCN)@@
Brad Turpin
DIAdem Product Support Engineer
(3,898 Views)
