DIAdem
Problem creating channel property in tdm file
Hi, Stefan:
Here it is:
static const char * FILE_Property_Test = "File Property Test";
Argument "file" is the DDCFileHandle
Greetings from Luebeck~~
Kuo
Message Edited by Kuo on 04-22-2010 09:59 AM
Message 11 of 17
(2,761 Views)
Hi Kuo
blanks are not supprted in property names.
Property names should only contain alpha numerical characters.
Gruß in den Norden
Stefan
The following characters are not allowed for custom property names:
., :, ,, ;, ', \, @, <, >, #, [, ], %, (, ), {, }, |, *, ?, =, !, ", ^, $, &, +, -, /, and a space
Also the following property names are reserved and may not be used for creating custom properties on file level:
author, channelgroups, children, datestring, datetime, description, environment, external_references, id, instance_attributes, mime_type, name, objecttype, parent, registercomments, registertxt1, registertxt2, registertxt3, timestring, title, version, version_date
The following property names are reserved and may not be used on group level:
 channels, children, description, equipments, external_references, id, index, instance_attributes, measurement_begin, measurement_end, measurement_quantities, mime_type, name, objecttype, parent, registertxt1, registertxt2, registertxt3, root, sequences, submatrices, submatrices, test, units_under_test, version, version_date
The following poperty names are resevered and may not be used on channel level:
 average, channel, children, datatype, deletebehaviour, description, dimension, displaytype, empty, external_references, flagkey, group, groupindex, id, implicit_increment, implicit_start, instance_attributes, internal_params, internal_res1, internal_res2, interpolation, is_scaled_by, length, lengthmax, local_columns, maximum, measurement, mime_type, minimum, monotony, name, novaluekey, number, objecttype, parent, quantity, rank, registerint1, registerint2, registerint3, registerint4, registerint5, registerint6, registertxt1, registertxt2, registertxt3, registerval1, registerval2, registerval3, registerval4, registerval5, registerval6, representation, scales, sourcedatafilename, sourcedatafilepath, sourcegenparam1, sourcegenparam2, sourcehandle, sourceinstancekey, sourcename, sourceparentname, sourcerepresentation, sourcetype, sourcevalue, standard_deviation, status, type_size, unit, unit_string, valuetype, version, version_date, waveform,
Message 12 of 17
(2,758 Views)
Hi, Stefan:
You are definitetly Genius~~
Now it's working~~
Thanks!!!
Kuo
Message 13 of 17
(2,756 Views)
Well if that is the case then the LabVIEW TDMS vis should not allow the use of spaces in property names.
Message 14 of 17
(2,142 Views)
TDMS does support white space in property names an property values. TDMS and TDM are different file formats.
Message 15 of 17
(2,138 Views)
Note: Other software than LabVIEW such as DIAdem or DataFinder cannot deal with e.g. spaces in property names and will replace 'forbidden' characters with '_'.
Message 16 of 17
(2,128 Views)
That's true. So far I used DIAdem fairly well.
Message 17 of 17
(2,125 Views)
