DIAdem
Problem with DAQmx and Diadem 8.1
Hi ...
I am trying to use Diadem 8.1 (the only version we have here) with a DAQpad-6015 (USB). For using the box I installed DAQmx 8.7. Then the box was found and I found it in MAX (measurement and automation explorer).
So far - so good.
No I started Diadem and after 20 seconds Diadem closes without any warning. I could work these 20 seconds. Then I uninstalled the DAQmx and Diadem works fine again.
Can you tell me which driver I could use for the DAQpad-6015 in combination with Diadem 8.1.
Thanks in advance and best regards
Steffen
(3,407 Views)
Hi Steffen,
this is a known problem with DAQmx 8.7.(1) . It should be solved in version 8.8 and above.
Currently you can downgrade to DAQmx 8.6.1 driver.
To remove DAQmx completely goto System Control -> Software -> National Instruments -> Add/Remove and remove:
 - NI-DAQmx 8.7.1
 - NI Measurement & Automation Explorer 4.x
 - Traditional NI-DAQ
After that you can install DAQmx 8.6.1:
http://joule.ni.com/nidu/cds/view/p/id/950/lang/de
Good luck and a sunny afternoon.
Ralf N.
Applications Engineering
Germany
(3,366 Views)
