DIAdem
Problem with FFT
Ohhh.. Also, this data was acquired using the controller on myRIO.. Will it be better if I employ the FPGA module ?
Message 11 of 16
(2,361 Views)
Hi deepen,
Better in what way?  The concern you've expressed (FFT amplitudes at higher frequencies) is related only to the data acquisition rate, which is variable in both controller acquisition and FPGA acquisition.  In either case you can change your data acquisition program to digitize data points at, say, 500Hz or 1000Hz instead of 76 Hz.
Brad Turpin
DIAdem Product Support Engineer
Message 12 of 16
(2,351 Views)
Hello Brad .. You have been really patient with my queries and i thank you for that 🙂
How did you calculate my sampling period by looking at my VI / data set ?
Also, I need to make sure i get to frequencies like 500-1000Hz .. what changes do you suggest in my VI that i can acquire and process that ?
Message 13 of 16
(2,348 Views)
Hi Deepen,
I looked at the values in your "Seconds" channel.  I took the last value and subtracted the first value from it and then divided by 3151.  I also calculated the delta times between each value of the "Seconds" channel and calculated the average of all the deltas.  Both ways gave me exactly 0.0139996826404316, which I rounded to 0.014.
You'll need to ask a LabVIEW support engineer for help configuring your acquisition rate to be faster.
Brad Turpin
Message 14 of 16
(2,340 Views)
Can I not change the 'wait' value on my loop where I acquire the accelerometer data ? Right now its at 2ms.
Message 15 of 16
(2,329 Views)
Hi deepen,
You're not really acquiring accelerometer data with software timing are you?  If so, why do you have a wait time of 2 ms when your "Seconds" channel clearly shows values spaced much larger than 2 ms apart?  Typically you would set up acceleromter data acquisition with hardware timing.  In single shot mode you would acquire all the data to a buffer and read it once at the end of the acquisition.  In continuous mode you would read the buffer about ever second or so and append the results to a file you're streaming to.  Again, these are questions for a LabVIEW support engineer.
Brad Turpin
Message 16 of 16
(2,321 Views)
