DIAdem
Problem with a data set: DIAdem crashes
I've got a problem with a data set. When I want to zoom in DIAdem-View, DIAdem crashes with the following message (translated from German ;-):
error type: FLOAT INEXACT RESULT or FLOAT INVALID OPERATION or FLOAT STACK CHECK
error address: 00016CB8
module name: gfsview.DLL
I've got some similar data set not showing such problems. Further on I scanned the data a bit, but in the 59000 points I didn't see anything special. I did try to delete "NOVALUE"s as well, but after that there still exist "NOVALUE"s.
Does anyone have an idea what to look for?
Carsten
(4,847 Views)
Hi Carsten,
Could you send me the data file (otmar.foehner@ni.com) or upload the file here for testing?
Also, please tell us which version of DIAdem (click on the '?' in the menu bar, then on 'About ...') you are using.
I'll check it out as soon as I get the file from you.
Otmar
Otmar D. Foehner
(4,847 Views)
Hi Otmar,
when saving the data in a .DAT file and reopening it, the problem doesn't occur. It just occurs when using the data imported from the Citadel database! Should I send you the complete Citadel database (currently about 9 MB in size)?
The DIAdem Version I'm using is 8.1.1292 (currently evaluation).
Carsten
(4,847 Views)
Carsten,
Could you please upload you Citadel database to the following FTP site:
ftp.ni.com/incoming
If you want to compress (ZIP) and/or put a password on the data, that's fine. Please send me a private email at otmar.foehner@ni.com (with the file name and password if you put one on the file) once you have uploaded the file and I will check it out.
Otmar
Otmar D. Foehner
(4,847 Views)
