DIAdem
Problem with command d2axisXtick (diadem 10.2)
I don't understand why d2axisXtick is not enabled.
call graphobjopen("2dXaxis1_1")
     d2axisXscaletype="manual"
     d2axisXtick =a
     d2axisXbegin=b
call graphobjclose("2dXaxis1_1")
In the diadem help, this command exist. But it is not reconized.
I use too the d2axisYtick which work!!!
I think its a diadem bug but im not sure.
If it is a bug, maybe an update exist and where is it?
Or It's not a bug. But what is it?
For more information, I joined my program (see line 162, 434)
Thank you very much.
(Sry for my english :))
Message 1 of 8
(4,844 Views)
Hello c.reverte!
D2AxisXTick still exist, only the syntax highlighting seem to have a problem with it. New in 10.2 (or other 10.x version) are the D2AxisXTickDist and D2AxisXTickChn variables.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
Message 2 of 8
(4,843 Views)
Thank you very much. It works 🙂
Message 3 of 8
(4,838 Views)
This command is reconized (writed in green)
but it doesnt work.
I need to read the x axis grid step.
As d2axisYtick for y axis.
thank you
Message 4 of 8
(4,836 Views)
i must to specifies the interval between the ticks but in the diadem help, there is only one command for that: d2axistick.
D2axistickdist is for specifies whether diadem takes the tick position.
Message 5 of 8
(4,833 Views)
Hello c.reverte!
The easiest way to determin these things is to open the settings dialog with the scaling and press Ctrl+A. Then you get a script in the clipboard with all settings. Paste it to an empty script page and cut out the things you need.
Matthias
Matthias Alleweldt
Twigeater?
Message 6 of 8
(4,830 Views)
It strange, in the script, it writed: d2axisxtick in black.
but i can modifie the grid step.
Very strange... 😞
Message 7 of 8
(4,827 Views)
Use the following script:
Call Graphobjopen(D2axisxobj(1))
D2axisXtick = 1
Call Graphobjclose(D2axisXobj(1))
Before that you have to define the scaling type as manual. for me its working fine..
Message 8 of 8
(4,668 Views)
