DIAdem
Problems with UDI Object initialization
A beautiful day,
Since already 5 days I have the problem that I cannot initialize UDI objects. Because when I start the Script each time this error is displays, although I already tried the solutions which finds from assistance, NI board and E-Book “Script DAC driver description”. My problem: I want to record data from a GPS Receiver (Racelogic VBox) to DIAdem Visual (not Report or View) over the COM2 Port.
DIAdem displays to this line:
Set oUDIM = CreateObject( "DIAdem.SFD.UDI" )
this Error:
Error: UDI: A no more specified error is arison. (in German: Ein nicht näher spezifizierter Fehler ist aufgetreten)
I don't know where is my failure or can it be that it gives problems with the UDI Objects and the DIAdem Evoluation Version I use ??? But i still have nearly 16days to test these version. I hope anybody can help me.
(4,017 Views)
Hallo Jules82,
erstmal würde mich interessieren, ob denn die Kommunikation mit dem MAX und dem Schnittstellenmonitor in DIAdem funktioniert. ´Bitte testen Sie dies erstmal.
MfG
Rebecca Fox
(3,974 Views)
