DIAdem
Programatically adding/moving report tables
I am trying to dynamically define tables in DIAdem Report. However, neither was table creation recorded during script recording, nor was I able to find any method for creation of a table. Alternatively, it might be enough if I was able to resize or at least move a report table from script. Is there any way to do it? Any suggestions would be most welcome.
(2,544 Views)
Hi Rashek
Please have a look at the DIAdem help for the topic 2DTable http://zone.ni.com/reference/en-XX/help/370858P-01/reportapi/objects/report_objects_ireptable2dint/
This help topic and other related topic contains a lot of examples that you could copy and use in your code.
You could call the help directly from the intellisense tooltip when you type your code.
Winfried
(2,528 Views)
