DIAdem
Programatically list all groups
I am trying to list all my groups in my data using GetChannelgroups() but it is only getting the last group. To show this, I opened a new DIAdem file with the example groups - EXAMPLE, Noise data, Results_Noise data, Room temperatures. It might be important to note that in the Data Portal, Room temperatures is bold. In the Script, I'm doing the following:
Dim oMyChannelGroups, oMyChnGrp
Set oMyChannelGroups = Data.GetChannelGroups("[]")
For Each oMyChnGrp in oMyChannelGroups
  Call MsgBoxDisp(oMyChnGrp.Name)
which only prints "Room temperatures". Is there a way to get all the group names?
(2,986 Views)
I figured it out! I misunderstood the explanation of the function. I needed to do `Data.GetChannelGroups("*")'.
(2,978 Views)
Your script is correct, simply replace the square brackets with a wildcard '*'.
Set oMyChannelGroups = Data.GetChannelGroups("*")
Empty square brackets returns only the default group.
(2,977 Views)
To get all just use
data.Root.ChannelGroups
(2,949 Views)
