DIAdem
Question about RowNoStr in StatBlockCalc
I'm trying to use StatBlockCalc in a VBS script.  I would like to calculate the average of the last few seconds (3 in the attached script below) of a data channel.  To do this, in my script I am determining what row numbers are the last 3 seconds of the channel.  Then, I am putting this into a "StatBlockCalc" command to calculate the average of these rows.  However, I retrieve the error, "The syntax for the line number is wrong." if I try to put a concatenated string for RowNoStr.  It works if I directly type it in (Row 19 in the script), but the concatenated version doesn't work (Row 21).  What am I doing wrong?  Please help!
Thank you!
Julia
(3,780 Views)
Hi Julia,
you only have to change the code for the concenated string. Because VBS can handle variants in most cases you can use this simple formula:
Call StatBlockCalc("Channel", AvgStartRow & "-" & AvgStopRow , MyChnName)
This will work, because VBS perfoms the conversion from numeric to string under the hood.
Stefan
(3,770 Views)
Thanks Stefan, I knew I was doing something silly.  I apprecitate the help!
Julia
(3,758 Views)
