DIAdem
RTFText Object
Hello
I am using a RTFText Object in a report template and I was wondering if there is a way to set the text in th eRTFT object programmatically.
I am using DIAdem 2015 32 bit
Regards
Tim
(3,277 Views)
Hi Tim,
The only option you have with the RTF object in REPORT is to embed "@T1@" type expressions in the RTF object, whose content you can then control from your VBScript.
Brad Turpin
DIAdem Product Support Engineer
(3,266 Views)
Excellent tip Brad!  This will help!
Tim
(3,263 Views)
