DIAdem
Rainflow matrix - Create Levelcrossing and Rangepair out of Rainflow matrix
Hi all,
i have the problem to get the levelcrossing ant the rangepair counting out of the rainflow matrix.
I have a load function an make a rainflow matrix with the diadem tool. Then, some changes shall be done in the matrix.
In the next step, i want the levelcrossing and the rangepair counting out of the "new" matrix.
Is there a diadem solution for this problem? Do you have any ideas?
Thank you very much for your support!!!
Thanks. Tobias
(4,310 Views)
Hi Tobias
I tried to reproduce the problem but I had no luck. Could you explain your problem a bit more in detail? Please send me as well a Screenshot or the DIAdem file that causes the problem.
Have a nice day!
Andreas
Ps: perhaps do you speak German? 🙂
(4,279 Views)
Hallo Andreas,
vielen Dank für Deine Antwort und Bemühungen.
Ich habe das Problem gelöst, indem ich mir entsprechende Scripte für die Rangepair und Level-crossing Zählung aus der Rainflowmatrix selbst geschrieben habe.
Vielen Dank und Gruß, Tobias
(4,256 Views)
