DIAdem
Read TDM file with python module “tdm_loader”
So i am trying to read a .tdm file with python and am using tdm_loader module.
Per
import numpy
import tdm_loader as tdm
data = tdm.OpenFile('DATA.TDM')
data.channel_name(0,0)
>Out[2]: 'Time'
But:
>data.channel(0,0)
results in:
Traceback (most recent call last):
File "<ipython-input-3-ab5f07c9eb08>", line 1, in <module>
data.channel(0,0)
File "C:\Users\sebastian\Anaconda3\lib\site-packages\tdm_loader\tdm_loader.py", line 231, in channel
data_usi = OpenFile._get_usi_from_txt(lc.findtext('values'))[0]
*IndexError: list index out of range*
> data.channel(0,1)
gives another error
File "<ipython-input-7-248c388cba15>", line 1, in <module>
data.channel(0,1)
File "C:\Users\sebastian\Anaconda3\lib\site-packages\tdm_loader\tdm_loader.py", line 238, in channel
ext_attribs = self._root.find(".//file/block[@id='{0}']".format(inc.get('external'))).attrib
AttributeError: 'NoneType' object has no attribute 'attrib'
I can access other .tdm files that go along with a .tdx file. But this .tdm file goes along with a .json and a .l03 file.
I don't know if this produces the problem? Any Advice is much appreciated.
(7,821 Views)
As  I know, it shouldn't both files can "work" with .tdm . It could be just syntaxes, check some examples.
Maybe You would try convert them to csv?
(7,755 Views)
If i use any other .tdm examples that go along with a .tdx file, everything works fine. Maybe tdm_loader is only compatible with a according .tdx
If i want to convert them i need to aim to convert it with Python (i want it all to happen with python) but therefore i would need something like tdm_loader. But it does not work for my files 😕
(7,732 Views)
Hi Sebasti,
I'm not familiar with the tdm_loader module for python.  In general, a *.TDM header file can reference one or more binary data files of any file extension.  So I'd be surprised if the tdm_loader module hardcoded the *.TDX file lookup, since the implicitly linked binary file names are listed inside the *.TDM.
What I can offer you is to try to load the *.TDM file that's giving you trouble with DIAdem or LabVIEW and let you know if it's a valid TDM file, from the NI perspective.
One other possibility is that a few years ago DIAdem added the feature to create *.TDM files where the *.TDM file contents was zipped.  It's possible that the tdm_loader can't handle that flavor of *.TDM file.  You might try opening the *.TDM file in NotePad and see if you get XML (not pretty, no spaces or endline characters), or if you see the sort of binary characters typical of a zipped file.  If that's the case, you can just rename the file extension from *.TDM to *.zip and use 7zip or WinZip or Windows Explorer to unzip the *.TDM/*.zip file.
Brad Turpin
Principal Technical Support Engineer
NI
(7,720 Views)
I can open the file with DIAdem and i also used Matlab to open the file. So yea my current guess is that tdm_loader did use some hard coding but i may just ask the creators in a next step. Seems like not a lot of people use python to work with tdm files?
I opened it with the editor and it is given in a .XML format 😕
Nevertheless thanks for the answer.
(7,711 Views)
Hi @ sebasti_94 ,
we recently open-sourced our project for decoding TDM/TDX . It is available at
https://pypi.org/project/TDMtermite/
and
https://github.com/RecordEvolution/TDMtermite
You're welcome to check it out!
Best regards
(7,662 Views)
