DIAdem
Recover TDMS Data with Diadem 11.0 and Labview 8.6
Accepted by Mpetrie
Hi Mpetrie:
I have recovered your 2 tdms files in the attachments.
The problem you faced is an old issue and we have fixed it. Please get the latest TDMS installer from http://zone.ni.com/devzone/cda/tut/p/id/9995 .
Message 11 of 19
(2,421 Views)
Thank you for the assistance.  I will install the new plugin, and work with a few other files that got corrupted.
Thank you.
Mike
Message 12 of 19
(2,412 Views)
I have two additional files at the moment that are also giving me the same error.  After installing the standalone plugin is there a specific thing I should do in Diadem or Labview to get access to the file data.  I tried to load it from both Labview via the Read Measurment SubVI and also register the data into Diadem, but both processes gave me an error.
I also noticed that the Diadem Navigator Window does not appear to recognize the file as a TDMS file, as the file ICON is representative of a TXT file not a TDMS file.  I have attached both the files and a picture of the icon difference.
If the ultimate solution is to upgrade to the recent versions of the software, let me know.  I can then see if there is space in the budget to acquire the new software package.
Mike
Message 13 of 19
(2,410 Views)
Hi Mpetrie:
The other 2 files are recovered in the attachments.
zaizhou.ma
Message 14 of 19
(2,397 Views)
Hello zaizhou ma,
could you tell me how to recover these problems, I have the same problem, I have a TDMS file about 650M, it's corrupted and we cannot take a same test again.
Thank you
Message 15 of 19
(1,949 Views)
Can you upload the file? I created a Labview application based on the information they provided me before to find the binary file error and correct it. I could post my labview application, but it may not make sense how to use it for someone else.
Message 16 of 19
(1,943 Views)
sorry, I can't upload the file, it's too large, and I failed upload it.
Message 17 of 19
(1,937 Views)
Have you looked into using something like DropBox or a similar file sharing service?
Otmar D. Foehner
Message 18 of 19
(1,918 Views)
Otmar, thans for your reply, I sent you a private message.
Message 19 of 19
(1,909 Views)
