DIAdem
Reduce digits for absolute time channels
i want to reduce the digits for a absolute time channel. The frequency is only 100Hz but the format is always:
("12.11.2021 11:02:50.6700", "#dd.mm.yyyy hh:nn:ss.ffff")
Can i change the time channel to :
("12.11.2021 11:02:50.67", "#dd.mm.yyyy hh:nn:ss.ff")
Thank you for your help
(1,573 Views)
Accepted by topic author AlexanderR_ACTS
Hi AlexanderR_ACTS,
If you use the command to format the time you can modify the formatting parameters like
msgbox str("12.11.2021 11:02:50.6700", "#dd.mm.yyyy hh:nn:ss.ffff")
or in VIEW you can change the formatting parameters for the table here
or in general in the DIAdem settings here
Greetings
Walter
(1,560 Views)
Thank you that was exactly what i was looking for 😄
(1,553 Views)
