DIAdem
Reduce pdf quality
Hallo,
I am exporting to .pdf a report with 30 sheets, in each sheet I have 6 graphs among which at least 2 waterfall maps (order analysis color maps).
The  generated report is very big and the export time is high, is there a way to reduce significantly the quality of exported diagrams?
Up to now I tried with the option REPORTPrintAsGraphic = 1 but I still have significant export time and size...
Thank you,
Mattia
(2,627 Views)
Accepted by topic author mattia_verona
Hello Marria,
There are several parameters that can be tweaked to change the PDF file size, try these for a start:
PDFResolution = "300 dpi" ' or "72 dpi", "150 DPI", "300 DPI", "600 DPI", "1200 DPI", "2400 DPI"
PDFJPGCompressed = "low" ' or "No" , "medium" , "high"
PDFOptimization = 1 ' or 0
PDFJPGCompressed = "No" ' or "low", "medium", "high"
You can look up the exact descriptions for each parameter in the DIAdem help system.
I hope this helps, ask if you have further questions.
Otmar D. Foehner
(2,571 Views)
