DIAdem
Replacing values in a .tdm
Hello everyone,
I am new on this board and I am new with the .tdm file-format and DIAdem. I use LabView 7.1 and DIAdem 9.1 and got a problem managing the values in my .tdm file. I attached a very simple program, that generates 10 random values an write them in a .tdm file. I can open it with DIAdem and got no problems so far. But my instention is, to replace these 10 values everytime, I start the test-vi but the values are appended.
Can anybody tell me, what wents wrong?
Thanks a lot,
kmel
(3,431 Views)
Hi kmel,
Your LabVIEW code looks fine to me, and when I run it repeatedly on my computer, which has only LabVIEW 8.21, I get a test.TDM file with a channel containing only 10 values, as desired.  I don't happen to have a LabVIEW 7.1 computer handy to test with, but I'd guess you've run into a bug that has been fixed in subsequent versions.
Brad Turpin
DIAdem Product Support Engineer
(3,418 Views)
Hello Brad,
thank you for your quick answer. I found another way to solve this problem in my application, but I think will update my LabView version soon, to avoid other bugs. On the other hand, I wonder who the same vi is working in different ways in two LabView versions...
Greetings,
kmel
Message Edited by kmel on 03-20-2007 10:22 AM
(3,416 Views)
