DIAdem
Report 2D table row heigh
In a report 2D table properties window there is a tab labeled "Scaling". Here you may set the table length scaling type and row height as percentage of page. Now, I'm trying to set these properties programatically. The first one is set through the D2TabAutoScalType property of a 2D Table, my simple question is how do you set the other one?
(3,745 Views)
Hello salte!
A Ctrl+A in this dialog and paste in an editor give you all values. In htis case it is 'D2TabColHeight'.
Matthias
Matthias Alleweldt
Project Engineer / Projektingenieur
Twigeater?
(3,743 Views)
Thats a nice tip, thanks! I looked for something like this in the help file but couldn't find it.
(3,741 Views)
Hello salte!
Unfortunately is the help in this case no help (exception to the ruleSmiley Wink ). Only in the documentation of 'D2TabAutoScalTyp' is a little note. In general the easiest way is to find the variable name via Ctrl+A and than use the help.
Matthias
Message Edited by Twigeater on 11-16-2007 09:58 AM
Matthias Alleweldt
Twigeater?
(3,739 Views)
