DIAdem
Report 2D table spanning several pages
I've created a report (using a script) that creates two 2D tables. The number of entries in each table depends on user input (timespan and number of channels), so I don't know how many pages the report will span across.
Is there a way of automaitcally exapdning the report to the number of pages required?
If not, what would be the best approach for solving this issue?
(3,699 Views)
Hi salte,
The easies way is to prepare a layout page which will be appended as much as pages are required. If you have a look at the example "Copying Signals into Channel Groups" you can see that the layout "ChannelGroups_Partial_Results.TDR" is appended several times.
Greetings
Walter
(3,687 Views)
Hi salte,
Here's an example of what Walter is talking about that uses 2D tables instead of 2D graphs.
Brad Turpin
DIAdem Product Support Engineer
(3,678 Views)
Thanks to both of you! I'll have a look at the examples when i get the time.
(3,674 Views)
